05-15-2022 08:30 - last edited on 12-18-2022 19:58 by
I’ve recently just purchased the Versa 3 having been a big fan of the original Versa. The built in gps was a selling point…..
1. Can someone help with seemingly 3 seconds delay when recording a run time. When I press ‘play’ to start the run - there’s clearly a delay before it starts recording time - 3seconds at present. How can I change this so when I press play it starts immediately??? It’s annoying to be honest.
2. any tips on gos connectivity - it takes ages to connect even following advice on these forums.
05-15-2022 12:40
05-15-2022 12:40
If you mean the initial timer, then tap the timer circle to skip countdown and start tracking immediately. For GPS, I don't know. I just got used to the fact that it takes ages to connect.
05-18-2022 09:31
05-18-2022 09:31
Thanks for the tip! I did think there should be a way to avoid a delay from the initial start.
Looks like I too will have to get used to the gps issue.
thanks for your help!
