07-13-2018 19:15
07-13-2018 19:15
Recently I have noticed that my Fitbit Versa is having a large battery drop, it can go from 63% to 21% in a single day. Does anyone else have these issues? I don’t use music or anything that could easily drain the battery, and I only do occasional checks. After a full charge my battery will go from 100% just down to 80(some)% but then eventually end up going 63% to 21%. Anyone else suffer these issues?
Best Answer07-13-2018 19:34
07-13-2018 19:34
I haven't noticed this .
Have you tried a restart or a shutdown?
When I had a battery issue on the ionic .a factory reset fixed the issue.
Found under settings, about .
07-13-2018 19:37
07-13-2018 19:37
Yes, I have had to reset it a couple of times in the past because of notification issues and it just running slow... maybe I’ll give it another shot though.
Best Answer07-13-2018 19:40
07-13-2018 19:40
Have you contacted Fitbit?
07-13-2018 19:44
07-13-2018 19:44
No not yet, I woke up this morning and had 65% and was down to 21% this evening, this was the 3rd or 4th time occurring. Does the warranty for the Versa cover battery issues?
