10-15-2018 01:12
10-15-2018 01:12
I am so disappointed, I love my Versa and it worked so well with my last phone which was Samsung, and now with my new Huawei Nova 3 it won't sync, and phone doesn't send notifications to my Versa, I can't even change my clockface. I didn't think that Huawei has these problems with Fitbit, I love my new phone too, and don't want to change it. But this sucks. And now I've read that Fitbit doesn't do anything to fix this problem.
Best Answer10-15-2018 02:17
10-15-2018 02:17
That phone is not on the Supported Devices List so it may or may not work. All you can do is work through all the troubleshoots in these Help Articles and hope something works.
Helen | Western Australia
10-15-2018 04:40
10-15-2018 04:40
Hello,
try this - Settings - Security and Privacy - Location access - tap on 3 dots in the right upper corner - Scan settings - Turn off Bluetooth scanning
after that open Fitbit app and try to sync it with Versa. This helped me with my P20 Pro which has the same chipset as Nova 3
Best Answer10-15-2018 04:58
10-15-2018 04:58
Yeah thanks I actually tried that a while ago and it works now yay, hopefully that problem is now solved.
Best Answer02-23-2019 03:24
02-23-2019 03:24
Yeah finally IT works on my fitbit charge 3 and Huawei nova 3, thanks
Best Answer05-16-2019 23:51
05-16-2019 23:51
Is it still working to u? I have Huawei Nova 3 and I wanna buy fitbit versa and I wanna be sure it will work fine.
Best Answer05-17-2019 00:04
05-17-2019 00:04
Yeah it started working fine after I installed the "sync fix for fitbit" app and still does. 😊
