03-13-2019
16:06
11:15
AlessFitbit
03-13-2019
16:06
11:15
AlessFitbit
Fitbit is very excited to announce Versa Lite.
Fitbit Versa Lite is the most affordable smartwatch yet and latest addition to the Fitbit Versa family of devices, Versa Lite Edition has all the core fitness and smart features of Fitbit Versa like activity, sleep and heart rate tracking, notifications, apps and 4+ day battery life—plus bold color choices and an easy one-button design. Versa Lite is easy-to-use, lightweight, comfortable and comes in new vibrant colors to appeal to a fun-seeking, youthful audience.
You can learn more about these new devices or place a pre-order at fitbit.com/versa.
If you have a question reply to me and i will answer back.
Best Answer03-13-2019 22:19
03-13-2019 22:19
Hello and welcome to the forums @Slatyer
This is what Fitbit posted here - click - on March 6th.
There is a help area for the Versa, which includes the user manual and related articles - click to go there
It's great you wish to help and that's what the community is all about. As for tricks using the Versa, you'll discover more about it the longer you use it.
Hope to see you around the forums.
03-13-2019 16:08
03-13-2019 16:08
I have a fitbit versa and i want to know any tricks i can use for it.
03-13-2019 22:19
03-14-2019
18:38
08:49
03-14-2019
18:38
08:49
Hi. Any idea when it's shipping?
the versa lite I pre-ordered ...
Best Answer03-16-2019 08:54
03-16-2019 08:54
Welcome on board @Slatyer! We're happy to hear you're interested in getting the Versa Lite. You can take a look at the information that @Odyssey13 has shared with you. ![]()
Hi there @lorenraye! Did you order the Versa Lite from the Fitbit store? If you did have you contacted Support to see the status of the order? Do you have any confirmation number or email stating the order status?
I look forward to your reply!
03-18-2019 10:18
03-18-2019 10:18
Hello. I am interested in getting a Versa Lite, however I am allergic to metal. I am wondering what material is on the watch face back. Most watches and fitness monitors have a metal back. I'm hoping this one is plastic.
Best Answer03-18-2019 12:23
03-18-2019 12:23
Hello! Can you tell me what the Bluetooth range is for this watch? I'm trying to find something I can wear while I teach a dance class to track my heart rate AND control my music, but my phone will be 35-55 feet away from me.
16:12
12:20
03-18-2019
16:12
12:20
The Fitbit Versa Lite Edition and Versa classic band is made of a flexible, durable material similar to that used in many sports watches, and includes an aluminium watch case and buckle. The woven band is made from a comfortable polyester and includes an aluminium watch case and buckle.
Edit: @KristenDances Many things can determine how close your phone needs to be for the bluetooth to connect. Typically it is about 20-30 ft, but walls, type of materials, etc can all effect that. Your heart rate will track no matter what.
Hope this helps.
Best Answer03-21-2019 12:25 - edited 03-21-2019 12:26
Welcome to the Fitbit Community @littlenyama and @KristenDances!
As my friend @Slatyer has shared with you, the range to setup or sync your tracker is around 20 to 25 ft from the Bluetooth device (either a computer or phone). I suggest you check that your phone is compatible to do the setup and sync.
On the other hand, the housing and buckle on Versa Lite Edition are made of anodized aluminum. While anodized aluminum can contain traces of nickel, which can cause an allergic reaction in someone with nickel sensitivity, the amount of nickel in all Fitbit products meets the European Union's stringent Nickel Directive.
If there's any questions present, let me know.
03-21-2019 12:36
03-21-2019 12:36
Hi @littlenyama. Here is the material information I found in the Fitbit Store.
Materials
The Fitbit Versa Lite Edition and Versa classic band is made of a flexible, durable material similar to that used in many sports watches, and includes an aluminum watch case and buckle. The woven band is made from a comfortable polyester and includes an aluminum watch case and buckle.
03-22-2019 12:33
03-22-2019 12:33
Thanks so much for your input @SunsetRunner! ![]()
04-25-2019 14:02
04-25-2019 14:02
Can you use the same interchangeable bands with the Versa and Versa Lite or are they different sizes?
Best Answer04-25-2019 14:10
04-25-2019 14:10
The bands are interchangeable, @GinaKBM .
04-25-2019 14:20
04-25-2019 14:20
Thank you, Carol!!! 🙂
