12-20-2018 22:28
12-20-2018 22:28
Hi All, my fitbit versa has suddenly stopped working properly after 1 month. The screen is just black but the Heartrate sensor on the back is active. After force-restarting via the left and lower right buttons, this is what happens:
1. Fitbit logo appears
2. After a while, Fitbit logo disappears then versa vibrates
3. Screen goes to the clock face and...
- when the screen goes to sleep, it will crash and restart again back to step 1 (fitbit logo)
- the touchscreen doesn't work
- buttons on the side of the watch work
- sometimes the clock face does appear and shows instead "clock error"
- sync with mobile phone works, even able to change clock faces
Any immediate help for this? I can't reset the unit since touchscreen doesn't work. It just loops around steps 1-3.
Best Answer12-21-2018 02:35
12-21-2018 02:35
@Shieh Try 3-button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
