The screen on my Fitbit Versa popped up but is still connected at the bottom (by the logo) underside. Does anyone know how to fix this? I am sure it needs a new seal. It was working at the time but now the battery is dead because it has not been on the charger.
Unfortunately, fitbits are not usually repairable and I've seen other posts with this problem where the fitbit had to be replaced.
I suggest that you contact customer support. They can check your warranty status and advise on your options: contact.fitbit.com
Best AnswerThank you for the reply. I have had the fitbit for over a year so no help there. I put the fitbit on the charger and it works fine, I just can't wear it because of the screen not being sealed. I did watch a You tube video of a guy replacing a broken screen...he just didn't show how to put a new seal in and pop the screen in place!
