06-22-2018 18:52
06-22-2018 18:52
So I have had my Versa for not even a month and it now won’t reapond. I was wearing it today and noticed that it wasn’t notifying me of my text messages. Got home and noticed that it wasn’t working at all. I tried multiple resets and recharging and it is unresponsive. It’s been working fine for the past 3 weeks. Help!
06-22-2018 23:57
06-22-2018 23:57
If several restarts havent worked, try a factory reset using the buttons. If that doesnt work you will need to contact support (link in my signature ) Let us know how you go
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
06-22-2018 23:57
06-22-2018 23:57
06-23-2018 05:34
06-23-2018 05:34
I tried the rest and it didn’t work. I contacted customer support and am waiting for their response. Thank you for all of the help and advice!
Best Answer09-05-2018 17:06
09-05-2018 17:06
09-05-2018 17:06
What was their reply
@Khiebler wrote:I tried the rest and it didn’t work. I contacted customer support and am waiting for their response. Thank you for all of the help and advice!
Best Answer09-05-2018 17:09
09-05-2018 17:09
Best Answer11-07-2018 06:31
11-07-2018 06:31
I am having problems with my Fitbit Versa, it first would not track activity even though it was connected to my Bluetooth. I shutdown Fitbit to reboot but it will not come back on.
