Fitbit Versa apps saving settings.
ANSWERED
It would be great if the Versa saved the settings it displays for exercises once I set them. Measuring all the stats and having  that data in the end is great. It can be a hassle "tapping" through different measurements to get to what I really want to see during my exercise though. As you can imagine I spend time at the beginning of each session re-configuring the app for my ease of use. Saving the configuration once selected just seems like a "no-brainer" to me. That having been said I am very pleased over all with my Versa.
1 BEST ANSWER
Accepted Solutions
@smax7019 This problem is resolved in the latest firmware release. They updated 10% of people then ran into a glitch with third party apps and stopped rolling the update out. If you want the update, you can factory reset your Versa. Just sync first so you don't lose data.
2 REPLIES 2
Wow! That really changed my whole outlook on my device. I reset my Versa and now it REFUSES to update or even acknowledge my factory supplied charger as legitimate device to be used for that purpose! There is NO reason it should be this hard to perform a simple update much less save the configuration settings for an app. I'm really hoping the team that develops the Fitbit apps and/or software for my device are replaced ASAP by someone that actually understands the concepts of simplicity and ease of use. Hopefully my warranty is worth the paper it's written on because at this point it looks like I'm going to have to return my device and pray the replacement is supported by software that doesn't require a PhD to configure. I have better things to do with my life than completely reconfigure this watch every time there is an update.
