Im not sure what you are asking here. Do you want to set up a pin number on the Versa?
Helen | Western Australia
Best AnswerYes you can do it.
In your app go to your account (id card icon) and select Versa. Scroll down and select Device Lock. First you need to set up a lock code on your phone, then you can proceed to set up a 4 digit pin on your Versa. It then expects you to go on and set up Fitbit pay, but just dont do that and go out of the Device lock screen, and the pin is set on your Versa.
Please come back if there is anything you cant do and we can try to sort it out.
Best AnswerUnfortunately i cant see your images so i am not sure where you are getting stuck. Do these images help?
select id card icon
select Versa
select Device Lock
Your device lock will say disabled (mine says enabled as I have just enabled it)
Best AnswerMine is 32.32.10.15 What is yours on?
Hi @TJ7472411 Is that a question? If so, I need a bit more information about what you are after.
