09-10-2018 18:24
09-10-2018 18:24
Hello there.
My Fitbit Versa is completely dead. I'm totally frustated. I bought my watch two months ago on USA, now I'm in Brazil. I tried a reset with two buttons, three buttons, it doesn't charge, I tried everything that I could and nothing happens. Last time I saw it working, it showed me a red triangle with an exclamation point, then suddenly I got a blank screen and it's gone. I tried to contact support but they told me Fitbit doesn't have a direct way of commerce with Brazil, so they are unable to send a replacement or help me to resolve this problem. Can someone help me with that? Is there another way to bring my watch back to life?
Thank you very much.
Best Answer09-11-2018 00:48
09-11-2018 00:48
Have you tried a Factory reset using the buttons? Worth a try Id say.
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
09-11-2018 03:49
09-11-2018 03:49
I am having exactly the same issue. It started off with my screen generally not displaying occasionally over the last few weeks... then not getting notifications from my phone.. and now completely dead. Wont charge. Have tried doing all the hold down button reset things and nothing. Still completely black screen. It's only 3months old. So frustrating. I've emailed the support team. If they give me anything to try that works I'll let you know!
Best Answer09-11-2018 07:18
09-11-2018 07:18
Thanks for the answer!
I already tried the factory reset, but unfortunately it doesn't work. The watch won't turn on.
Best Answer09-11-2018 07:20
09-11-2018 07:20
Thanks!
Please let me know if they answer you. It must be a solution for this. It's really frustrating.
Best Answer09-11-2018 08:47
09-11-2018 08:47
Contact support and get it replaced.
Best Answer09-11-2018 09:06
09-11-2018 09:06
This worked thanks... not sure why it went dead but it is most annoying on a new watch that I have with the same issue.
Best Answer09-15-2018 12:05
09-15-2018 12:05
Two Versa’s in 3 months. The first one lasted 2 weeks 😞 Both have totally died and won’t reset no matter what I do. And customer service directs you to video yourself doing the fixes, and wait for like 3 weeks for a replacement. This is the WORST service ever.
Best Answer10-10-2018 16:22
10-10-2018 16:22
Less than two weeks old ... tried the 3 button reset ..nothing, just a triangle and exclamation mark. Rubbish device rubbish brand.
Best Answer06-17-2019 10:53
06-17-2019 10:53
Hi my fitbit versa is completely dead not charging done all reset it's just dead
Best Answer06-17-2019 17:25
06-17-2019 17:25
There was nothing that could be done when I contacted them. They just sent me a brand new versa watch face based on what I told them.. So I assume it's happened a lot.. They didn't even want the other one back. Basically told me to just chuck it out! I don't use it anymore so can't comment on whether I've had any further issues
Best Answer10-08-2019 06:17
10-08-2019 06:17
I have same problem. Versa completely dead. have tried all suggestions. How do I get help?
Best Answer10-08-2019 16:01
10-08-2019 16:01
I contacted fitbit support services directly.. They just asked for proof of purchase and then mailed out a brand new replacement face. They didn't even need me to return the old dead one despite me offering in case they wanted to try and investigate further.
Best Answer10-10-2019 06:18
10-10-2019 06:18
Best Answer10-10-2019 14:15
10-10-2019 14:15
You'll just need to scroll to the bottom of the page and ensure the country selected is correct to make sure the right contacts come up (click on the drop down menu to change it if required)
