02-19-2019 11:37
02-19-2019 11:37
Opened my app today to sync and look at my stats and discovered that my Fitbit has not been syncing for four days. I’ve already reset the Fitbit itself 3 times, disconnected the Bluetooth and reconnected it, restarted my phone and deleted the app and redownloaded it. Still not syncing.
Any other ideas?
02-19-2019 12:09
02-19-2019 12:09
@Kait5991 Phone model and OS? For now, try this:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected (on Android) and All day sync are enabled.
02-19-2019 12:09
02-19-2019 12:09
02-19-2019 14:19
02-19-2019 14:19
iPhone XS Max ios 12.1.4
Well something seems to have helped, now i have heart rate on the app for part of today, but no heart rate for the past couple of days or sleep even though when i looked at the Fitbit on my wrist it was tracking... weird but guess it’s gone? 😕
02-27-2019 19:15
02-27-2019 19:15
@Kait5991 Is it missing from your Dashboard on Fitbit.com as well? Perhaps it was a hiccup during the sync?
02-28-2019 21:07
02-28-2019 21:07
Unfortunately it is, very weird
03-01-2019 09:24
03-01-2019 09:24
@Kait5991 My best guess would be it got messed up during sync. It may happen if the device hasn't been synced for a while. Also, fitbit will store detailed stats only for the last 7 days, I believe.
10-09-2019 20:57
10-09-2019 20:57
You mentioned this: Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it. I can't find ANY place on the Fitbit app to remove wifi. Mine hasn't synced for 4 days now.
I have latest Fitbit app. I also have a phone that syncs with my Versa. Its the Hauwei Honor 6X.
10-10-2019 11:02
10-10-2019 11:02
@UpsetWalker Which Versa do you have? Wifi is available only on Versa 1 and 2, not on Lite...
10-10-2019 15:11
10-10-2019 15:11
Versa One I believe. Versa 2 is the new one? If that's the case then mine is a versa 1, bought it in April.
