08-22-2018
14:50
06:07
AlejandraFitbit
08-22-2018
14:50
06:07
AlejandraFitbit
My Fitbit Versa will not sync, I have followed instructions, rebooted many times, removed other stuff from Bluetooth yet still nothing. Nor will it let me change the clock time which is wrong nor can I change the clock face. I'd be grateful for help before I end up returning back to the shop.
Best Answer08-22-2018 14:53
08-22-2018 14:53
I have just read it may be because it's not compatible with my phone, Huawei psmart, yet I am getting notifications for the device to say it's synced when it hasnt.
Plus it synced the first night I got it.
08-22-2018 14:53
08-22-2018 14:53
08-23-2018
06:08
17:15
08-23-2018
06:08
17:15
It's great to see you around @Jackiecs.
Thanks for troubleshooting this by yourself. When a phone isn't compatible, it doesn't mean that it won't work with your watch but you might experience some connectivity issues.
You can always try the instructions provide in the following links, but I don't guarantee it will work 100%.
Catch you later. ![]()
Best Answer08-23-2018 06:12
08-23-2018 06:12
08-24-2018
05:25
17:14
08-24-2018
05:25
17:14
Those are great news @Jackiecs.
I am glad to hear that your Fitbit is now working properly. If there is anything else we can do for you, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer08-24-2018 12:47
08-24-2018 12:47
Best Answer08-25-2018 03:17
08-25-2018 03:17
having the same issue. Any updates? Thanks
Best Answer08-25-2018 03:20
08-25-2018 03:20
Best Answer08-25-2018 03:25
08-25-2018 03:25
I have gone through steps via live chat today for more than an hour. They can't fix it. the agent talking to me said the only way is to select the right time zone and sync, which i have tried for a whole day.
Best Answer08-25-2018 03:28
08-25-2018 03:28
Best Answer08-25-2018 05:30
08-25-2018 05:30
Hey I just figured out the solution so you may want to try.I
finally decided to factory reset and went through all set up steps and it works.
For anyone trying to fix this issue, you may factory reset it. I succeeded after a whole day and more than an hour of live chat with fitbit which didn't help.
