Have you down loaded the fitbit app?
If you have then:
1 Tap the top right rectangle icon.
2 Then scroll down the screen till you see setup new device.
3 Tap setup new device.
4 Select your device type.
5 If your phone is connected the device is neaarby and on it should display a code. type that into your phone then fallow the setup steps.
Best AnswerHello @Ethel12 may I ask what type of computer or phone is being used to set up the Versa?
At what step does the setup process fail and so you get any errors?
Are you following the setup process?
