Fitbit Versa
I purchased a Fitbit Versa for my husband at Sam's Wholesale and they told me that I had to register the item with Fitbit for their warranty to be added and if I didn't then both warranties would be void. However, I do not see where to register this item.  Please advise.  Thank you
1 REPLY 1
Hi @Crystal1983
There is no warranty registration process per se. By setting up and using your Fitbit, the date you started using it is the date generally used for the warranty. If you have your receipt, that will help you if there is any problem.
Glad you're with us.
Stepping in the U.S.A. since September 2013. Android 14
