01-13-2020 11:47
01-13-2020 11:47
Hi guys. I bought my Fitbit Versa 2 about a month ago and sometimes the screen comes on but then if I touch the screen it won’t work. I have restarted it a few times already.
Should i take it back? What do you guys suggest it is?
Please help.
Thanks.
01-13-2020 12:48
01-13-2020 12:48
Hi @CearaN , restart your Versa 2 three times in a row (internal reset). If that does not solve your problem, contact Customer Support. This should not happen, regards kuzibri
Best Answer01-13-2020 20:56
01-13-2020 20:56
Thanks @SunsetRunner I will definitely try it and let you know.
