I disconnected my versa from pixel 3 due to syncing issue. Now when I try to pair again, the phone found the versa and a new token was generated. After entering the code the phone shows an error
"This device has been locked and cannot be paired. This may happen if a device is reported lost or if a warranty replacement has been issued. If you believe this is in error, please contact Customer Support."
Can you please help
Hi, @Spider1286! Sounds like you should contact Fitbit Support directly.
MakMak | Community Council
Thank you..
