01-30-2019 10:42
01-30-2019 10:42
My versa screen has gone white and bo longer works. I bought it in september and can't figure out how to fix it. I have tried troubleshooting and nothing has worked.
Best Answer01-30-2019 11:20
01-30-2019 14:16
01-30-2019 14:16
Hi, contact Customer Support about your problem, seems a hardware issue.
Best Answer02-05-2019 15:50
02-05-2019 15:50
I have used the reset process successfully, but it keeps recurring. Specifically I have reset it 3 times over the last 48 hours. It was not doing this for the first week or 2 I had the device. Was there an update?
Is my device defective?
The reset works, but I should not need to do this on a daily basis.
Best Answer02-05-2019 15:54
02-05-2019 15:54
See my post above yours.
