Hi @brymark A couple of things to try. Do several restarts. Try a factory reset. Change the clock face you are using in the app (if it will sync). If none of these help then you need to contact Support
BUTTON FACTORY RESET FOR VERSA 2
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Helen | Western Australia
