10-09-2024
10:13
11:00
ManuFitbit
10-09-2024
10:13
11:00
ManuFitbit
I would buy a new device, but literally just want a very small device that logs steps.
The app updated. Now I cant sync. Still cant sync after trying the things below. Im open to ideas. Thanks
-bluetooth on and off -restart phone -restart app -remove and attempt To reconnect the device(failed) -Reinstall the app
Moderator edit: clarified subject.
10-10-2024 11:11
10-10-2024 11:11
Hi @conikco2. Welcome to the community forums.
Thank you for providing the details regarding the difficulty that you are experiencing with the device and for trying to fix it on your own.
Please, confirm that you have followed the steps listed in this help article:
10-19-2024 06:23
10-19-2024 06:23
Try syncing with your Versa on the charger. Sometimes that works for me. If it doesn’t, login to the website & try syncing from your dashboard there vs using the App. Good luck!
