12-25-2018 09:32
12-25-2018 09:32
How do it set up so I have flashlight and I can reply to text messages on iOS
Best Answer12-25-2018 10:13
12-25-2018 10:13
Hi, setting up a Flashlight is possible, replying to text messages in not possible AFAIK. The Versa will only give you a notification that you got a message, so you can go to your mobile device in order to read and respond to it.
How to setup a Flashlight:
1. Go to apps - All apps
2. Press All apps.
3. Go to the search icon on top of the screen on the right.
4. Type Flashlight and press search
5. You will see two Flashlight apps mentioned at the top of the list. I would recommend the one on top, cause that one is better than the second mentioned app.
6. Press that app and install it.
7. After having installed it, it will be on your Versa on the apps screen and when you press it, it becomes a bright white screen.
Good luck and Happy Holidays.
