08-26-2021 18:06
08-26-2021 18:06
When i tap on my face, calories is the only thing that showing. It should change from pulse, steps and pulse.
Best Answer08-27-2021 05:39
08-27-2021 05:39
Hi @Vfreeze you didn't mention which device. If the only thing you see on the device is your burned calories, then you need to be sure it's been set up. Here are the directions for setting it up - click to go there.
Best Answer08-27-2021 08:00
08-27-2021 08:00
Best Answer08-27-2021 11:37
08-27-2021 11:37
I'll move your post to the Versa area so you can get more relevant responses. Have you tried restarting the device? Another suggestion usually is to change the clock face.
