02-22-2019 19:04
02-22-2019 19:04
My versa has worked awesome until a couple days ago it is tracking my heart rate at peak for 6 to 8 hours. During this time I have Worked out and been at work sitting with very little activity It’s obviously a glitch or broke. Wondering if anyone knows a reset or fix for this ??
Best Answer02-22-2019 19:04
02-22-2019 19:04
Best Answer02-22-2019 20:40
02-22-2019 20:40
Hi @TinaMC89 Try restarting your Versa several times and see if that fixes it. If it doesnt, please come back here.
Helen | Western Australia
Best Answer02-22-2019 21:32
02-22-2019 21:32
I have the exact same problem. I have turned the HR on/off multiple times trying to correct the issue. Plus turning versa off, and finally a factory reset, nothing has resolved the issue for more than a few minutes. Started about a week ago for me, right after an app update. If you find a fix, I would appreciate that information. Good luck.
Best Answer02-23-2019 04:05
02-23-2019 04:05
Best Answer02-23-2019 10:57
02-23-2019 10:57
