08-02-2022 17:25
08-02-2022 17:25
My Fitbit started acting up the past couple of days. The LED lights are red instead of green, and the heart rate monitor is not connected. It also isn’t properly tracking my steps/activity/sleep. I’ve tried troubleshooting it a few times and it still won’t reset. Please help!
Best Answer08-03-2022 05:03
08-03-2022 05:03
Hello @caimoore
You mentioned troubleshooting your Versa Lite a few times but it was unsuccessful. You didn’t mention which troubleshooting steps you took so I apologize if I suggest something you might have already tried. You mentioned your Fitbit isn’t properly tracking your steps/activities/sleep. Once your heart rate is functioning properly you will see an improvement with your sleep tracking as it needs the heart rate readings to track sleep. A restart might help other issues as well.
Let’s try this: Go to your Versa Lite and swipe left until you see the setting gear icon and tap it. Look for heart rate and disable it. Open your Fitbit App and swipe down on the page to force a sync with your Fitbit. Once the Fitbit is successfully synced then go back to the heart rate on your Versa Lite and enable it and again sync your Versa Lite.
If the issue persist try restarting your Versa Lite by holding down the button on your Versa Lite until you see the Fitbit Logo then release the button. You should feel your Versa Lite vibrate indicating it has completed the restart.
😉 Hopefully this gets your heart rate monitoring up and running again. Please let me know how it goes.
Best Answer08-03-2022 07:45
08-03-2022 07:45
I tried all these steps and mine still isn’t working, there is no light of any colour on mine does that mean it’s broke?
Best Answer08-03-2022 07:49
08-03-2022 07:49
同じトラブルを抱えているので試したが、ダメでした。残念!
Best Answer09-02-2022 21:34
09-02-2022 21:34
1か月死んでいた心拍数モニターが突然生き返りました。何をやっても駄目だったのでガーミンに買い替えようと思っていた矢先の出来事で驚いています。
Best Answer09-06-2022 09:07
09-06-2022 09:07
I’m happy to hear your heart rate is back up and running again @kenn70jp
Best Answer09-06-2022 09:09
09-06-2022 09:09
Best Answer09-06-2022 09:25
09-06-2022 09:25
Hello @KatieMahon
I would suggest contacting Fitbit Customer service since the troubleshooting tips I provided earlier didn’t respond to the issue. Here are ways to contact them:
https://myhelp.fitbit.com/s/support?language=en_US
Best Answer09-06-2022 13:04
09-06-2022 13:04
I’ve tried the customer service route….zero help for the same issue. Fitbit bugs up the software, then Bob in Mumbai gets to deal with the angry users. Shame. Last time I had this issue a year or so ago, an update fixed the oxygen monitor. Bob was unable to help, because the problem was in the update. Good luck.
