Just did a dive trip using my Versa as a secondary dive watch.
Deepest dive - - 142 ft (Blue Hole Belize)
No problem with the Versa.
Best Answer"I am wondering if there is an app or a way to know how many feet/meters I am diving to! Does this exist? Is it possible for smart watches like the Versa to know how deep we are swimming? "
Now THAT is an excellent idea! I love it. Problem is that the range of the barometric pressure sensor is simply not large enough. I don't know exactly which sensor is inside the tracker, but as a reference I looked at the Bosch bmp280 https://www.bosch-sensortec.com/bst/products/all_products/bmp280 which has a max pressure of 1100hPa = 1.1*10^5 Pa = 0.11Bar = 1.1m of water.... So .... Bummer.
Effectively, one needs a dedicated underwater pressure sensor to make this possible, like those found in diving watches. As Fitbit is already lagging behind competition on swimming applications, I suspect diving applications and sensor hardware are even further off from the radar. But the idea is good!
