12-27-2018
16:17
18:55
EdsonFitbit
12-27-2018
16:17
18:55
EdsonFitbit
How do I change the face on my versa?
Moderator edit: added label
12-27-2018 17:17
12-27-2018 17:17
Ah, @katsully. You’re asking about the fun stuff. I enjoy trying out the various watch faces!
To do this, open your Fitbit app.
Have fun!
Best Answer12-27-2018 17:27
12-27-2018 17:27
Hi, changing the clock face is not that difficult: open the Fitbit app and you will get, when you're logged in, the Fitbit's dashboard with all the stats. On the top of the screen at the right side you will see the icon of a watch. Press that and it will bring you to a new page where Clock Faces should be present. If yes, press Clock faces and you'll get a screen with on the left side "My clock" (the one you're using now) and on the right side "all Clocks". Press that one and you will be brought to a page where you can see all the clocj faces that are avalaible. Scroll through them and choose which face you like (mind you that you have to pay for some of these faces, which I do not recommend), press it and install it. Wait after the installation for about 20 secs cause some faces show after that in the page settings and permissions. In the settings you can customize the face to whatever you like and with the permissions, press that and enable then all. Happy hunting!!
12-27-2018 17:55
12-27-2018 17:55
I took your advice and it worked perfectly. Thank you for mentioning that you have to pay for some of them. Will it tell you that you have to pay for it when you choose select?
Best Answer12-27-2018 18:00
12-27-2018 18:00
Most of the time it does and gives you a trial period from 1 hour to 24 hours, but some do not.
12-27-2018 18:41
12-27-2018 18:41
