02-28-2022
03:37
20:24
02-28-2022
03:37
20:24
I woke up ten minutes late this morning because i guess my alarm snoozed automatically after, what, a minute? I don't have time in my morning routine for my alarm to just assume i don't need to wake up at the designated time. Any way to disable this "feature"? I want my watch to vibrate until i tell it to stop.
@Pictus Here is a link to the Versa 3 manual. The instructions for the Alarms app is on p 42. The way I read the instructions, your Versa 3 is behaving as programmed -- it will snooze in after one minute. It doesn't look like you can set it to vibrate until you shut it off.
Laurie | Maryland
04-10-2022
21:11
11:51
04-10-2022
21:11
11:51
Hi @Pictus - the vibrate is very weak so you may not feel it easily, especially if you are a heavy sleeper, also it gets weaker as the battery level falls so keep well charged.
Also have a look at smart wake option.
Unfortunately there isn't an option to make a sound when the alarm alerts.
