How do I set up notifications on Versa 3?
ANSWERED
Hi, I have just got new versa 3 and completed the set up. However, I am struggling with the below:
- currently no phone calls, messages are coming through on versa, even if I have app on.
- no Spotify control from versa. What set up needs to be done here?
- also have changed in versa setting that I would like analog clock, but it doesnt seem to update. I have switched off the always display on mode.
Please assist.
Thanks
1 BEST ANSWER
Accepted Solutions
Hi, @SruT , for help with notifications, please can you let us know which phone you use?
For Spotify control you need to put the app on your Versa.  You do this from the Fitbit app on your phone.  Make sure you sync to add it to your Versa.
To change your clock you need to set it up initially in the app and then ass it to your Versa by syncing.  Once clock faces are added to your Versa you can swap amongst them on the Versa itself. Swipe left on your Versa until you come to clocks and then swipe left to see which clock faces are loaded.
If the clock you have chosen is not there, make sure you have synced your Versa.
I hope this helps.  Welcome to the forums.
2 REPLIES 2
How do you add Spotify to your Versa. I need a step by step. I just feel overwhelmed.  Lol
