05-19-2018 15:17 - last edited on 05-28-2018 09:11 by AlejandraFitbit
Just got Versa today. "Instructions" what there were of them were no help. Since I was a Charge client I already had the Fitbit app on my computer. What else do I need to do to set this thing up?
05-19-2018 16:42
05-19-2018 16:42
@Morgan2 wrote:Just got Versa today. "Instrructions" what there were of them were no help. Since I was a Charge client I already had the fitbit app on my computer. What ELSE do I need to do to set this thing up????
05-19-2018 16:42
05-19-2018 16:42
05-27-2018 11:50
05-27-2018 11:50
Thank you for the sage advise. Had I been told the manual was online when I received the product, I would have.
05-28-2018 09:14
05-28-2018 09:14
It's great to see you around @Morgan2 and @SunsetRunner thanks for stopping by.
I would like to know if the instructions provided by our friend worked? Are you still having issues pairing your Versa? If you do, I recommend verifying that you are doing the following from the Fitbit app:
Also, if you want to have the Versa manual, click here.
Let me know if you need anything else.
06-03-2018 16:11
06-03-2018 16:11
Hi. Will I loose my steps in the workweek hustle if I add my new versa and remove my Alta?
06-03-2018 18:47
06-03-2018 18:47
No, you won't lose anything. Your data, regardless which Fitbit it is from, is stored in the same place.
05-23-2019 12:53
05-23-2019 12:53
I just bought a Versa...I have had two other fitbits and my husband is also on the account with his versa. I went through the steps mentioned... but versa did not come up as an option. I do not want to use my phone to connect, only the computer. Any suggestions?
11-24-2019 06:21
11-24-2019 06:21
so my phone says its synced but the versa 2 keeps scrolling all different languages and I don't see the versa2 on my app yet. it's still showing the Charge 2. how do I finish the sync to the versa 2?
