05-08-2018
18:01
09:04
AlejandraFitbit
05-08-2018
18:01
09:04
AlejandraFitbit
How do you turn off quick view on the Versa? My Blaze had the option to turn off but I can’t find any info on how to turn it off in Versa.
Best Answer05-08-2018 18:05
05-08-2018 18:05
never mind, i found it. OP please delete thread.
thanks
Best Answer05-09-2018 09:06
05-09-2018 09:06
Great to see you around @sourpatch35.
I am glad to see here that you were able to find where you can disable the quick view option. For more information about the Versa, you can take a look at the manual and if you need anything else, do not hesitate to post it.
Keep the stepping up. ![]()
Best Answer05-22-2018 16:39
05-22-2018 16:39
Can you still post the answer for those of us who don't know?
Best Answer05-23-2018 06:07
05-23-2018 06:07
Hey @Jewel999, a warm welcome to the Community.
To turn off the quick view option, you just need to do the following from your Versa:
Let me know if you need anything else. ![]()
10-03-2018 00:51
10-03-2018 00:51
What is the difference between the screenwake on the Versa it’s self and the quickview button on the app?
Thank you
Best Answer02-26-2019 14:41
02-26-2019 14:41
There is no difference. The Screenwake on the watch means that you don't have to open the app just to change the setting. This is a great idea so that you can easily turn off the quick view during the night.
Best Answer10-26-2019 22:06
10-26-2019 22:06
Sorry are you able to provide instructions on how to exit from quick settings screens. Top button on right brings up music, pay etc. Other buttons do nothing. Frustrating not being able to get to the watch!
Best Answer10-27-2019 03:55
10-27-2019 03:55
Hello @Di_Di and a warm welcome. So sorry you are frustrated. There was a firmware upgrade since this thread was started. I wear a Versa 2. I believe your Versa works the same way. If you swipe down on your watch face, a shortcut link is at the top and disappears in about two seconds. Tap on the toggle s and it should take you to the shortcuts that were on the left button. Tap on the image of a watch.
Laurie | Maryland
Best Answer11-11-2019 08:39
11-11-2019 08:39
My Versa continuously goes back and forth from Quick Settings to the main face ...vibrating and making a sound. How do I fix this issue? thank you
