12-05-2018 01:59
12-05-2018 01:59
Hello All,
I have set up my password on for my fitbit but i have noticed that it doesnt lock soon after putting the password in and id like to know if there is something on my watch that i must press to lock it once i am done on it as i would be done and then after an hour i would want to see something and i wouldnt need to put my password it as its unlocked
Best Answer12-05-2018 02:06
12-05-2018 02:06
The lock on your Versa does not activate every time you you wake it up. It should ask you to unlock once a day, and if you take it off it should ask you to unlock when you put it back on, and at other ramdom times it may ask you to. There is no way you can make it lock immediately. If you are using Fitbit pay there is an option to just lock the Fitbit Pay App so you have to unlock every time you use fitbit pay, but the reat of the watch functions are not locked.
I got a bit lost in your question so come back if youd like more info.
Helen | Western Australia
12-05-2018 02:06
12-05-2018 02:06
12-05-2018 02:17
12-05-2018 02:17
Thanks that helped alot. Sorry i didnt know exactly how to explain it but thanks. I understand now
Best Answer12-05-2018 02:19
12-05-2018 02:19
Thanks that helped a lot. Sorry i didn't know exactly how to explain it but thanks. I understand now
