10-16-2022
06:59
17:05
10-16-2022
06:59
17:05
Do I need to manually turn on the microphone prior to sleep or will the sleep report app automatically turn it on? I usually have it turned off during the day to conserve the battery.
10-16-2022 07:58
10-16-2022 07:58
By "sleep report" do you mean "Snore Detection"? If so, be forewarned, That is a big battery drain. Unless you are willing to charge your device every day or 2, it is probably best to use just for a day or 2 to get a baseline, then turn off. Then try again in at least a few weeks or when you suspect there might be a change.
In answer to your question, not sure but I think snore detect handles microphone itself.
Best Answer10-18-2022 07:33
10-18-2022 07:33
Thank you, @JohnnyRow . I’ll try turning it off and see if snore detect still works.
Best Answer10-20-2022 04:35
10-20-2022 04:35
Follow up: I manually turned off the microphone, and Snore Report was not generated; indicating to me that having the report function turned on would not automatically turn on the microphone once sleep was detected. I will need to turn on the microphone when I go to bed and turn off in the morning to conserve the battery throughout the day.
Best Answer10-20-2022 08:07 - edited 10-20-2022 08:07
@JJ55 Sorry for having given bad advice. I haven't used that for a while, and must not have remembered correctly. At least you know now.
Best Answer10-21-2022 04:44
10-21-2022 04:44
Your advice was fine. I wasn’t clear on what I was trying to figure out, but now I know. No worries!
