07-08-2018
23:59
04:57
AlvaroFitbit
07-08-2018
23:59
04:57
AlvaroFitbit
I can not work out how to stop a exercise on my versa? Also as I pressed the wrong exercise my swim has come up as a run but I thought it automatically recognised exercise that you had programmed into your versa?
Best AnswerOk if you want to stop an exercise (youve pressed the wrong one or you have finished) press the bottom left button. It will then show a little flag by the top left button (finish line flag ). Press this one and then it will ask you to confirm you want to end and tap the end on the screen.
Yes, you are right that the versa will auto recognise a number of activities, or you can start and stop them manually. One or the other. So if you start the exercise using the exercise app the auto recognise feature wont kick in as it thinks you have started the exercise so you will know when to stop it. But if you would like to use Smart Track's auto recognition then dont open the exercise app and dont start the activity manually.
I hopenthat is clearer for you now!
Helen | Western Australia
07-09-2018
00:58
05:08
AlvaroFitbit
07-09-2018
00:58
05:08
AlvaroFitbit
Hello nellyg
Thankyou yes you have explained it well I found the flag and stopped my run that I have been doing since 6.30 🤣😂
Sent from my iPhone
14:17
05:07
AlvaroFitbit
11-28-2018
14:17
05:07
AlvaroFitbit
Hi Nelly,
Do you mean the top and bottom buttons on the right side of watch? I have only one button in the middle on the left on my Versos.
Thanks
@fitshri Welcome to the Fitbit Community! I hope you're doing well! @NellyG did mean the right side of your Versa. You scroll to the exercise area on your Verse then select the one you wish oto use, tap it then tap the play button at the left bottom corner to start it, tap the same place to pause it the the green flag at the top right corner to finish the exercise mode. You can read more about it here.
Let me know how it goes!
