I’m new to swimming so I don’t tumble at the end of the pool yet. The measurements I get are inconsistent. Sometimes I swim 50 m and the watch says 25 m. Then I swim another 50 and it says 75. I’d like to feel like I can trust my stats so I can start measuring improvements.
Hello @Kcjean and welcome to the community. I'm sorry I can't give you a firm answer as to why you get wacky numbers. But I can steer you to a Help article that might help you with your tracking issue.
First, make sure you have your pool length correct. On the Versa itself, go to Swim in your exercise list > tap on the Gear > set the correct pool length.
Here is the link to the Help article. You might get some insight. I hope it helps.
Laurie | Maryland
Hello. I had this problem with my Versa and was unsure how to change it. Thanks for your advice. Now when I go swimming, it will reflect the correct distance.
