12-10-2018
22:22
05:23
AlvaroFitbit
12-10-2018
22:22
05:23
AlvaroFitbit
How do I change the temperature in the weather from Celsius to Fahrenheit?
12-11-2018
05:24
10:12
12-11-2018
05:24
10:12
@Texasgirl1 Welcome! It's great to see you around! You can change the weather units on your Versa by following these instructions:
FITBIT OS 2.1 OR EARLIER
From the Fitbit app dashboard, tap the Account icon (User-added image) > Advanced Settings > Units.
In the Length section, select a different measurement. Centimeters, Kilometers corresponds with Celsius and Feet, Miles corresponds with Fahrenheit.
Sync your device and then open the Weather app (User-added image) on your device to see the updated units.
FITBIT OS 2.2 & FITBIT CHARGE 3
Open the Fitbit app and tap the Account icon (User-added image) > your device image.
Tap Apps.
Tap the gear icon (User-added image) next to Weather. You may need to scroll down to find the app.
In the Temperature Unit section, tap Units and choose the unit you want to use.
Let me know how it goes!
Best Answer12-16-2018 22:53
12-16-2018 22:53
Thank you, I will try it....😙
Best Answer12-16-2018 23:33
12-16-2018 23:33
I have the newest Versa...
Having trouble with changing temperature in the weather app.
Need to change from celcius to Fahrenheit.
Anyone else having this problem?
12-16-2018 23:37
12-16-2018 23:37
Have tried this...
No luck...
May have to try customer support??
Best Answer12-17-2018 03:49
12-17-2018 03:49
I went into apps,found weather,changed it to farenheit. Then sync again and it changed. Yea,and hope it works for you too!
Best Answer12-28-2018 07:24
12-28-2018 07:24
Go to your accts, click on Versa under device, click on Apps, then click on the weather app, click on the settings icon and then unit. I just figured this out and changed mine and synced my Versa and it worked. Hope this helped.
01-01-2019 14:14
01-01-2019 14:14
Yes , I tried the fix but it still doesn't work
Best Answer01-01-2019 14:17
01-01-2019 14:17
Yes, that worked great !!! TY so much
Best Answer01-01-2019 15:07
01-01-2019 15:07
Went to Customer Support, they fixed my issues.
Best Answer02-03-2019 05:42
02-03-2019 05:42
This worked for me! Thanks!
Best Answer02-03-2019 08:23 - edited 02-03-2019 08:24
Hi, click in the dashboard of your Fitbit app on top of the screen on the watch icon. It brings you to the page with the Clocks and App Tiles. Click on Apps and you get a screen with "My apps" and "All Apps". Scroll down in the list of My Apps untill you see the weather app. Right next to it, there is the settings icon, press that and you will see a page with "Temperature Unit" and "List of cities". Press on "unit" directly underneath Temperature unit and a screen pops up with Celsius and Farhenheit. Press the one you want and click "Done" on the botton of this screen on the right side. Ready! To be extra sure it is changed, restart your Versa by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons.
Best Answer02-25-2019 03:28
02-25-2019 03:28
I can’t seem to get my Versa to change Celsius to Fahrenheit
Best Answer03-18-2019 12:47
03-18-2019 12:47
When I go into my apps, for some reason, the weather app isn't showing up. This means I have no way of fixing the problem, which is irritating. Any suggestions?
Best Answer03-18-2019 13:01
03-18-2019 13:01
Hi, go to All Apps and click the search icon on top of the screen on the right side. On the new page. press the search icon on top of the screen on the left sise and type Weather and install it. After that, follow the suggestions in my earlier post.
03-22-2019
19:26
10:11
03-22-2019
19:26
10:11
@bjgross7 @TheatreGeekHope Welcome! Thanks for being part of our Community!
Sorry to hear that you are having issues with your weather app and for the delay in my reply.
@bjgross7 please go to your Versa settings then go to apps and change the settings on the weather app.
@TheatreGeekHope did you try the suggestions @SunsetRunner shared with you? Please try them and keep us updated.
Let me know how it goes.
Best Answer06-03-2022 10:59
06-03-2022 10:59
When I click on my device Apps is not an option. My Versa switched from F to C in the last day or so. As far as zi know, I did nothing to cause this. .
06-03-2022 11:59
06-03-2022 11:59
I did all you suggested. I found the weather app reinstalled it and made sure the units were set to F.
i synced but watch still showed units in C,
I turned off the Versa 3 snd had a lot of difficulty getting it to restart.
Now it shows nothing but the watch face!
It appears to be scrolling when I swipe up but only a black screen displays. Curiously, if I scroll Up multiple times, I have to scroll down tge same number of times to get back to the watch face. But none of my current data, weather, exercise etc is displayed since I restarted.when I go to the weather option separately, it still displays in C.
Best Answer06-04-2022 15:06
06-04-2022 15:06
Based on past history with Fitbit products this is sound advice. That said, I ran a Fitbit app update earlier this week and since then weather will only display Celsius. My settings in the app’s “units’ as well as in the weather bug app are set to Fahrenheit. I have synced multiple times and even deleted and re-added my Versa 3 twice. It still displays the temperature in Celsius. I now suspect the Fitbit App update applied to my iPhone is the culprit. My guess is this won’t change until another update.
