04-18-2018 02:47
04-18-2018 02:47
Hey, I wanted to ask for help. The Versa automatically sets itself to an input device whether I want to or not, so I can't use that method. I also have noticed that if I am already connected to my headphones. I won't get the controls AT ALL. I can only get controls working by being connected solely to the Versa and changing source from phone to watch and then back to phone. Does anyone know how to fix this so I can at least get the source method working even while being connected to my bluetooth headphones? Thanks.
Best Answer04-19-2018 09:34
04-19-2018 09:34
This may not be helpful at all but I see Spotify is listed in the subject. I read that FitBit and Spotify are not capable at this time.
And what do you mean controls? Controls on your headphones, watch or phone?
Best Answer04-19-2018 11:19
04-19-2018 11:19
I meant controls on the watch. The watch is able to control Spotify which is playing for your phone (so you don't literally have to have the phone exactly on you, but somewhere nearby) but only if you don't have any headphones connected, otherwise it fails to recognize there's any audio playing. You can still control it if you first set it up and then connect your headphones without letting your Versa fall asleep and go back to the clockface, but it's a real pain to watch out for that. I was trying to ask if someone finally found a way to fix it. Thank you for your response nonetheless!
04-19-2018 11:28
04-19-2018 11:28
Hook the headphones up to your phone and use the watch to control Spotify on your phone via Bluetooth.
Best Answer05-16-2018 20:20
05-16-2018 20:20
The following tips on play Spotify Music via BlueTooth are shared with you. You can have a try!
