06-17-2022
18:52
17:58
06-17-2022
18:52
17:58
I am so annoyed at how difficult it seems to be. How on earth do i remove the glucose tile from my dashboard on my iphone?
06-17-2022 19:21
06-17-2022 19:21
Edit button near top right; X in circle on glucose tile.
Not really that difficult, at least when you know how.
06-17-2022 19:21
06-17-2022 19:21
06-17-2022 19:53
06-17-2022 19:53
Ah yeah i see it now, i swear that the edit option wasn’t showing before but anyhow i’ve sorted it now so thanks.
Best Answer06-17-2022 20:16
06-17-2022 20:16
Also once in Edit, can drag around tiles to put ones you use most often near the top. And can get into Edit mode just by touching a tile for a few seconds, not using the Edit button (which can lead to unintentional actions).
Best Answer06-17-2022 20:28
06-17-2022 20:28
Thank you that’s brilliant info!
Best Answer06-17-2022 21:54
06-17-2022 21:54
And if you accidentally delete a tile, or decide you want one back, scroll to the bottom in Edit mode to see all the tiles you can add, including ones you deleted.
Best Answer02-10-2023 23:47
02-10-2023 23:47
Hiya! I genuinely don’t see ‘edit’ anywhere…help? 🙂
Best Answer02-11-2023 03:13
