Hi, I would advicde you to place your post in the Feature Suggestions Board as this is especially created for these kind of requests. Click on the link and on the right side you'll see "Make a new suggestion", click this and type in your request. Other users who want the same as you can then vote for your request. The more votes you get, the greater the chance that it will be honoured by Fitbit as a supported app.
Best AnswerHi,
did you manage to connect OKOk with your Fitbit?
The okok app has an option on the settings to connect with the Fitbit app, when I clicked on it, fitbit asked me to give permision-that I did, but doesn’t seam to be working for me. If anyone has managed to connect them, any help would be highly appreciated!
Thanks
Best AnswerHi, as I already mentioned this app is not supported by Fitbit yet. If I go to the Feature Suggestions Board, I do not see that you posted a request in that board for this app to be supported by FitBit, so please, post your request there.
Best AnswerJ'ai autorisé l'accès à okok ça fonctionne le problème c'est que je ne peux plus me servir de l'appli fitbit. Dès que je clique pour entrer mes aliment okok s'ouvre. Comment retirer l'autorisation. Merci
