Hi, @Laladwilson! I would just suggest tracking it as a generic "workout." If you like, you can rename it after the fact.
MakMak | Community Council
Best AnswerThank you. I have been using that 1 but wasn't sure if there was another compatible app or something that tracks starThank you. I have been using that 1 but wasn't sure if there was another compatible app or something that tracks stairs.
Best AnswerNope, not really! If you wanted to see your elevation as part of the workout, you could use walk, hike, or run and that would give you flights as data. Otherwise, you'll just see them as part of your daily statistics.
