01-23-2019 06:29
01-23-2019 06:29
Showing 'Undefined' where the steps should show, and nothing showing on the BPM icon on watch face. Only just disappeared yesterday - any suggestions on how to get it showing again, please?
Best Answer01-23-2019 08:08 - edited 01-23-2019 08:26
Hi, in the Dashboard of your Fitbit app, press the watch icon on top of the screen on the right side, this will bring you to the page where the Clock Faces tile is shown, press that and you'll see "My clock" and "All clocks" . In my clock the name of your current clock should be present.
BTW: the default Clock Face for the Versa is called "Layers" and for the Versa Special Edition it is "Light".
01-23-2019 07:49
01-23-2019 07:49
Hi, would you be so kind to send me the name of your watch face (Clock Faces - press it - you see My clock and the name of it? Meanwhile you can try to restart your Versa several times by pressing and holding the left and right lower buttons untill the Fitbit logo appears and release the buttons. Maybe that will solve your problem.
Best Answer01-23-2019 07:54
01-23-2019 07:54
Hi @Souxsue. When you look to see the name of the clock face, please also check to see if it was developed by someone other than Fitbit. If this is the case, you should see a link to contact the developer. They may be able to help.
01-23-2019 08:00
01-23-2019 08:00
Thanks but can't find 'clock faces' to press!! Have tried pressing side buttons but that does not work either. Will try later .......
Best Answer01-23-2019 08:03
01-23-2019 08:03
Thanks - had this clock face since getting my Versa 6 months ago and can't remember but think it was a Fitbit one I used ...... will try later !
Best Answer01-23-2019 08:04
01-23-2019 08:04
Thanks am trying several options - will let you know how I get on later .....
01-23-2019 11:29
01-23-2019 11:29
01-23-2019 11:38
01-23-2019 11:38
Hi, March Blossom is indeed a Third Party clock Face and not one by Fitbit itself. If you problems still persists, despite restarting etc, you can contact the Developer (Press Clock Faces - All Clocks - Press the search icon on top of the screen on the right side and press on the left in the search bar and type March Blossom and click it. On the page that will be opened , you will see the name of the developer, e.g. Eduard Gridan and directly under his name a link that let's you contact the developer.
01-24-2019 05:42
01-24-2019 05:42
Hi - Thought I'd let you know decided just to uninstall my clock face and then after looking at others just reinstalled the original (same one) again. It worked as I now have all the correct icons showing ..........
thanks for all suggestions - very helpful!! Kind regards Sue
