Hi, am I uderstanding you well that you want to know if the syncing between Versa and phone is visible? When my assumtion is correct: wheven fitbit app on your phone is syncing with your Versa, you'ss see in the Dashboard of the Fitbit app tw things:
1. The little point between the brackets directly above the battery icon and right next to the watch icon on top of the screen starts flickering
2. After a short while you will see a blue line cominf from the left side of the screen on top and moving towards the right side on the screen. Once completed, the little dot stops flickering and the stats are updated.
