10-18-2023 05:49
10-18-2023 05:49
Time displayed is 50 minutes behind actual time. Persists after syncing. Notice it is taking longer to sync than usual and I phone Fitbit app does not update the correct battery life % when it says sync is complete
10-18-2023 06:01
10-18-2023 06:01
If you have time zone set to ‘auto’ under your settings, you might try turning that off & select it manually. I had issues w/the time on my Versa that were fixed by doing this.
Did this problem start after an iOS update? What version & iPhone model do you have?
