01-16-2020
12:12
04:21
DavideFitbit
01-16-2020
12:12
04:21
DavideFitbit
Time 2 hours behind
Best Answer01-16-2020 13:10
01-16-2020 13:10
Hi @yrserve , are you using a Third Party clock Face? If yes, change it to one developed by Fitbit itself and restart your Versa and the rpoblem should be solved. Regards kuzibri
Best Answer01-16-2020 13:15
01-16-2020 13:15
Since it is off exactly 2 hours, your time zone setting is probably incorrect. Go to Fitbit.com and click on the gear icon at the upper right and then Settings. Scroll down to Time zone and set it correctly. Then scroll on down and click on Submit and then sync your tracker.
Best Answer01-20-2020 07:21
01-20-2020 07:21
No 3rd party. Cannot reset. Screne stays on a red X and ask me to sync. Watch wont move from this screne
07:23
04:21
DavideFitbit
01-20-2020
07:23
04:21
DavideFitbit
The watch reset to right time. Then...it went to a screne with a red X and ask me to sync watch will move from this screne. I've tried everything
Best Answer01-20-2020 07:24
01-20-2020 07:24
Contact Customer Support.
