03-10-2022
08:39
20:21
03-10-2022
08:39
20:21
My Versa3 suddenly started counting too many floors - WAY too many. For example, in December, I averaged around 5-10 floors a day; now it's counting 50-70 a day. Trust me, I'd know if I added that many stairs to my routine. I've tried deleting the app and reinstalling; resetting my Versa3; letting the battery die all the way down and recharging it, but nothing seems to be working.
Any ideas?
03-10-2022 12:31
03-10-2022 12:31
Hi @Giteacher2 - did you do a firmware update since December?
If you are really interested in how your watch pressure sensor is behaving or whether you can get a more accurate floor count, you can verify you don't have a watch problem by using the SimpleFloors app.
The App shows how your watch is affected by environmental issues such as, going room to room, upstairs/downstairs, inside to outside, changes in temperature, etc.
It is always a good idea to restart the watch - How do I restart my Fitbit device?
This App is only meant for checking purposes as it uses the battery a lot, but at least it will give you an idea if your watch is fine or if it is some other issue.
Best Answer03-10-2022 12:32
03-10-2022 12:32
Hi Giteacher2,
Ik heb deze ervaring ook met mijn oude Ionic als het hard waait. Buiten (in het vlakke Nederland/Holland) fietsend gaf mijn Ionic al veel verdiepingen bij krachtige wind. Hij registreerde verandering van luchtdruk. Ik weet niet of/hoe dat kan worden uitgeschakeld. Ik heb sinds vandaag
Groet,
PalJaS Nederland Europa
03-10-2022 13:22
03-10-2022 13:22
How do I update firmware? I'm honestly not sure.
Best Answer03-10-2022 13:26
03-10-2022 13:26
Bedankt voor de informatie
Best Answer03-10-2022 15:02
03-10-2022 15:02
Hallo ,@Kerel_ Hartelijk dank voor uw informatie
Best Answer03-10-2022 20:32
03-10-2022 20:32
@Giteacher2 - you'll be notified if there is a firmware update, so obviously there hasn't been one, or you would know.
It was necessary to know if the watch behaviour changed by itself or if something else changed for it to start miscalculating floors.
