Hi @trex827! Welcome to the Fitbit Community.
The wristbands on Versa are similar, but will not be compatible with Blaze wristbands. Both bands attach to the watch with different mechanisms. Versa has plenty of accessories you can check out in the store, if you want to take a closer look. ![]()
The connecting mechanism on the Versa looks very similar to the one on the Blaze. Maybe a fitbit member of staff could confirm this.
You might not see any on the Fitbit website yet, but on Amazon there's always a variety of bands. The will be on Amazon once the versa starts shipping.
Best AnswerWhat about the Ionic bands? Would they fit a versa?
Best AnswerThis really stinks that blaze bands can't be used with versa as I have 3 which I REAlLy like and my blaze is just over a year old and one of the lights on back is out. Spoke to customer service and all he. Could do was give me 25% off "select" watches on the site.
Husband ordered a versa off "A" for good price and now what do I do with the practically new bands I own???
@Chickadee6 Welcome to our Fitbit Community! I'm sorry to her about the experience you had with the bands. I also appreciate your feedback about the 25% off on select watches offered.
This info helps us to keep improving.
@SunsetRunner Thank you for your help my friend!
See you guys around!
Best AnswerI know this post is kind of old but... I have been looking at pictures of bands for the 2 trackers and if the width of the band where the pins are located are the same length for both models then it looks like it would fit unless a different size pin is used. I have seen some bands being marketed to be compatible for both and the reviews say that they fit without any problems. The only reason why I would think that it has been said that a Versa band wouldn't fit on a Blaze is because the silicone bands for the Blaze have ridges. I have some Blaze bands that are of different material/not silicone and don't have those ridges and fit without any problems on the frame. The only reason why I keep looking to see if a Versa band will fit on a Blaze is because the selections for the Blaze are starting to get smaller and other trackers have more cooler bands and my Blaze still works so I don't want a new tracker unless someone gives me a Versa as a gift or if, which so rarely happens to me, I just so happen win one in a contest/giveaway. Haha. ![]()
Best AnswerHello Rose I saw your post about the blaze bands and versa bands being interchangeable. I just purchased a versa2 But have a Fitbit blaze also. I found out that they are not interchangeable unfortunately. I now I’m trying to sell my Fitbit blaze and 12 bands. If you are interested let me know and I can send you a picture. I was asking $75 for the blaze and the 12 bands, charger and some screen protectors. I have a silver metal band, a sporty pink and black one, and numerous black-and-white ones that I have never even used.
