02-04-2019 16:37
02-04-2019 16:37
I have been using my Versa for about two months. The BPM readings on the watch do not show up on the daily tracker at the same levels. My peal levels on the watch are much lower on the daily tracker. Many times I look at my watch, showing a BPM of say 104, or 110, yet when I go back to my daily tracker my peak BPM for that time was in the low 90s? When I work out on the tread machine, and the elliptical, both indicated I was holding peak BPM rate near 140 bpm for almost 10 to 12 minutes. Going back to my daily, the peak for that same period was only 115? Does the daily average the peaks over time? Is this a settings issue? Does anyone else have this issue. Is this normal.
Best Answer02-04-2019 16:50
02-04-2019 16:50
Hi, as far as I'm concerned, the Versa is in almost 98% accurate. If it is not, I clean the sensor with soft cotton.
