09-08-2018
11:15
07:13
AlejandraFitbit
09-08-2018
11:15
07:13
AlejandraFitbit
Have charged to 100%. Uploaded Fitbit app to mobile. Supposedly synced 2 devices. Don't know how to open Versa screen, keeps saying "pls download Fitbit".
Best Answer09-08-2018 12:01
09-08-2018 12:01
Guessing there is another versa nearby already paired - check the blue-tooth settings on your mobile and forget all devices. When it discovers trackers check how many versas are available. You may have to take one out of range, or temporarily switch off the other versa, to know which one is your Rose-gold one 😉 Once connected it will see it as the primary tracker and no longer be an issue.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
Best Answer09-10-2018 07:14
09-10-2018 07:14
Welcome to the Forums @Wendy-Joburg and @wmchapman thanks for stopping by.
I appreciate all the efforts in trying to fix this and would like to know if you keep having problems pairing your Versa? If so, I recommend taking a look at the help article Why can't I set up my Fitbit device? and follow the instructions provide there.
Let me know the outcome. ![]()
Best Answer09-10-2018 08:08
09-10-2018 08:08
