07-30-2019 04:06
07-30-2019 04:06
my fitbit has gone from cals to kls... how do i change it back pls
07-30-2019 04:39
07-30-2019 04:39
Go into the account section of the app (select your profile at the top left if you are on the new design; select the "ID card" icon at the top right if you are on the old design). Then scroll down and select "Advanced settings". On the next screen select "units" and you should then be able to choose between kilocalories and kilojoules
