05-20-2018 14:03
05-20-2018 14:03
I plugged my Fitbit up before I used it when I brought it. I got my fitbit on the 18th .Today is the 20th and it is only on 60% so 3 days so far without charging it is awesome! I'm just wondering if I need to let my fitbit die all the way before I charge it or not?
Best Answer05-20-2018 14:26
05-20-2018 14:26
@Mns6163 wrote:I plugged my Fitbit up before I used it when I brought it. I got my fitbit on the 18th .Today is the 20th and it is only on 60% so 3 days so far without charging it is awesome! I'm just wondering if I need to let my fitbit die all the way before I charge it or not?
I wouldn't let it go below 10%. There shouldn't be a problem letting it go down all the way but some folks have reported problems getting it started back up so better safe than sorry.
05-20-2018 14:26
05-20-2018 14:26
05-20-2018 14:35
05-20-2018 14:35
Thank you so much!! You are a life saver!! What kind of fitbit do you have?
Best Answer05-20-2018 14:37
05-20-2018 14:37
I have an Ionic and a Charge 2. The Ionic uses the exact same Operating System as the Versa.
05-20-2018 17:28
05-20-2018 17:28
Mine made it exactly 5 days with a single charge. But then it was completely dead. Spring back to life after about 3 mins on the charger.
05-20-2018 18:43
05-20-2018 18:43
It is not a good idea to run Lithium Ion batteries down to zero. I know we all do at times, but for better battery life recharge at 10% minimum. Preferably more. See
https://help.fitbit.com/articles/en_US/Help_article/2004
http://batteryuniversity.com/
Helen | Western Australia
05-20-2018 21:47
05-20-2018 21:47
I never knew that. I always was under the impression that to let it completely die was the best. Well I guess I learn something new everyday. Will never let it die completely. Thanks for the tip!!!
Best Answer05-21-2018 02:03
05-21-2018 02:03
It is NOT good to run them to zero, so why does Fitbit not give us the ability to turn the devices off?
Best Answer05-21-2018 05:30
05-21-2018 05:30
I was at 30% after 4 days. I was surprised how quickly the battery drained on day 5. So keep an eye on that. Obviously it’s not linear. The gauge isn’t 100% correct. I will charge after 4 days now.
Best Answer05-21-2018 07:18
05-21-2018 07:18
@GreginJaxFL wrote:It is NOT good to run them to zero, so why does Fitbit not give us the ability to turn the devices off?
Swipe left to Settings. Touch and scroll down to About. Touch and scroll down to Shutdown (AKA "turn off").
05-21-2018 07:25
05-21-2018 07:25
I get about 2.5 days out of mine. I don't mind though, as I work a desk job and can charge it at any time of the day. I'm sure once I get all of my settings refined, and more updates roll out, it should get better.......I'm hoping.
