03-19-2024 18:00
03-19-2024 18:00
I've had my Versa 3 a couple years now. As of late, I noticed the wrist wake function not working right, so I did the long press of the left button to open that menu.
Once the menu opens however, I can't actually open or access any of the options. I can click on each one, but nothing happens. So frustrating.
My watch charged for almost an hour today, Bluetooth is connected, everything is syncing fine and I tried a reboot.
Any other suggestions??
03-19-2024 18:16
03-19-2024 18:16
As far as Screen Wake, check if you are accidentally in Sleep Mode in Quick Settings.
Also try Restart if this isn't what you meant by reboot.
Best Answer03-19-2024 18:30
03-19-2024 18:30
Thanks for replying, but that's actually the whole problem. I can't access the quick settings. I touch the little dot next to quick settings, voice assistant, music settings, fitbit pay etc, and nothing happens.
Best Answer03-19-2024 19:12
03-19-2024 19:12
Can you swipe between screens?
Best Answer03-19-2024 21:38 - edited 03-20-2024 19:43
Hi @Joyous503 - are you able to double tap the watch, swipe the watch face to the right to get to Quick Settings and remove Sleep mode?
