04-25-2025
03:34
14:31
ManuFitbit
04-25-2025
03:34
14:31
ManuFitbit
There is an alarm that goes off every morning on my versa 2. I never set this alarm and there is not a reminder alarm setting to turn off as indicated in the instructions when I Google how to fix this problem.
Moderator edit: clarified subject.
04-26-2025 14:26
04-26-2025 14:26
Hi @Sjdobb. Welcome to the community forums.
Thank you for sharing the information about your Versa 2. Thank you for trying to solve the difficulty with the alarm.
Please, take a look at the points listed in this help article: How do I manage alarms on my Fitbit device?
05-02-2025 21:32
05-02-2025 21:32
Hi @Sjdobb - this may be an alarm set by Alexa, if you use it, and can be quite hard to find.
Just in case try turning off the phone's Bluetooth at night and see if the alarm still triggers.
Also to check the alarm type, in case it is different, set an alarm on the watch for a few minutes from now and check when it goes off if it is the same display as your morning one.
When you remove the test alarm check there are no alarms visible in Alarms.
05-05-2025 23:51
